RE: A&M 3.2
Not likely a Sachs crank would have an A&M rod on it....A&M rods had pressed in bearings, if your wrist pin bearing is not pressed in and the rod is copper colored the rod and crank are Sachs.,,,Look for a small centering hole in the end of the crank, no hole means A&M....
