RCU Forums - View Single Post - Headers for MVVS 58 and 45
Old 02-16-2007 | 10:00 AM
pe reivers
Default RE: Headers for MVVS 58 and 45
When you go inverted, the VA-DB2 will be excellent, if you use the right height difference between exhaust port and fuselage tunnel (drop) Such a header can be made to order. Standard drops are 25 and 50 mm. Different drop dimensions will not be a problem, but extra jigging time must be accounted for.
Edit:
The coupler is a separate part, and not included with the header
