MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Headers for MVVS 58 and 45
Old 02-15-2007 | 05:50 PM
Default RE: Headers for MVVS 58 and 45
you must braze the ball joints.
If you can meet your end of the bargain, I will keep mine, or I will refund. [8D]
Old 02-16-2007 | 08:59 AM
Miketc's Avatar
Thanks Pe, not sure where I can get someone to do the brazing. I will go with an inverted set up, what about the VA -DB 2 or the VA – DBW 2, Stainless options? Will this work? (I will need to sign up for Paypal)
A further question, When buying a header, would this include the Teflon coupler?
Mike
Old 02-16-2007 | 10:00 AM
When you go inverted, the VA-DB2 will be excellent, if you use the right height difference between exhaust port and fuselage tunnel (drop) Such a header can be made to order. Standard drops are 25 and 50 mm. Different drop dimensions will not be a problem, but extra jigging time must be accounted for.
Edit:
The coupler is a separate part, and not included with the header
Old 02-17-2007 | 12:52 AM
Why not tilt the engine down a little. Your stock header will line up properly then. That's what I have done, works great!
