Engine Test bench
Hello,
I'm using the cold weekend to build a test bench for some engines i have in the basement. These are somewhat small (.42 two stroke and .82 four stroke) and I wondered if anyone had ideas or designs to help me.
My plan is to fix a small block of some sort to cradle and mount the engine with a spot for a servo behind and a place to rubber band a small removable fuel tank behind as well. I want to then be able to take the block and attach it to a standard stanley vice table that is portable (that way I can take it outside, lock the mount into the table, and fire up the engine).
Has anyone put together such a contraption or have any pictures or instructions? Anything I should think about or plan for ahead of time? I want to make sure it is stable and yet still able to move inside and out without too much trouble.
Zach
