RCU Forums - View Single Post - lanier ripper ailerons install
Old 02-16-2007 | 06:19 PM
Capn America
Default RE: lanier ripper ailerons install
ORIGINAL: secret_squirrel
I am picturing folding the packing tape in half sticky side down and almost (and I do mean almost so that gaps aren't created) inserting it into the space between the ailerons and wing.
Am I on the right track?
Dan
Not sure what you mean, I take 2 pieces and overlap the sticky to sticky. insert it between the wing and aileron and stick one side to the top of the wing and other side to the bottom of the aileron then reverse the process right next to the first one so the it results in an X. Folding the bi di in half would make it harder to insert If im following you correctly...
You can pull the aileron away just a little to insert the tape then pull it tight and stick the tape. I have even put all 6 tapes in place then inserted the aileron and stuck everything fast. takes a little more planning but seems to save time.
