T-Craft
Mine looks great also,,,,but the control horns that came with the plane all has THREE holes to mount them and the screw count was for "2" per horn. The instructions also refered to 2 hole horns. I also had a problem with alignment on the tail section. After I squared the horz. stab I was left with a different measurement from side-to-side from the center of the fuse. I ended up trimming 3/16" from one of the elevator halves to clear the side of the fuse, barely noticable.......I am using one of my converted 30cc Homelites for power, tapped the Bennett muffler and will be using a Bennett smoke pump.
