RE: Esky Lama V3
Frymire: No, only 1 servo should move. What you describe is the correct behavior. To understand why the servo pushes the swash plate at an angle, look up something called 'gyroscopic progression'...
I'm not sure what is causing your problem, however. Perhaps one of the servo arms or links are binding on something, such as motor wires, etc.?
