RE: Webra 32 Carb Help Needed
It's hard to see but it looks like your HS needle spring clip is there. If it isn't some needles self adjust while running. And if your prop is such a load and you barely get on pipe staticly on the ground and in the air you really unload and get on pipe more your going to burn more plugs without being richer.
