RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 02-18-2007 | 08:10 AM
  #1216
CrashPro's Avatar
CrashPro
Default RE: Nitro models pusher Bobcat?
ORIGINAL: patzane
So the elevator use 2 mini servos.
What about the rudder alir, thro, frist wheel.
Also do the OS 61 has more power than the Tower Hobby 75. I think I seen that somewhere on here
I just order this plane last night and expect to be here wed.
My friend Serge mounted an O.S. .61 on his Bobcat, I went with the Tower 75 on mine. With APC 11x7 props, in straight and level flight, I'm able to walk (not run) away from him. Best I've got on the radar gun so far is 110 mph. We've both since mounted .91's on our Bobcats, his with an .O.S. , mine with a Magnum. We have a couple different props to experiment with today. We're starting with 14x7 three blade Master Air Screws cut down to about 13". We also have 16x10 three blades cut down to 12" Will probably end up cutting that one down to 11" or less, will know after todays flights. Temps around 80 degees and 4 mph breeze right down the runway forecast for today. Its 5am and time to load up the trailer and get ready to head to the field. Will post results of the prop experiments later on today, maybe some video too.
