THe OEM gyro in your Axe is a very lost cost rate gyro that leaves a lot to be desired as far as performance goes. What you would be doing if you choose to install, per the installation instructions, the separate gyro is getting a heading hold only gyro. Which is perfectly okay.
Carl
ORIGINAL: bryon261
this gyro from futaba, does this replace my current gyro? is the gyro in my axe a heading hold gyro? if the answer is yes than all i'm doing is upgrading to a better gyro.
