RCU Forums - View Single Post - CMP giant scale Zero build
Old 02-18-2007 | 01:58 PM
paladin
My Feedback: (9)
Default RE: CMP giant scale Zero build
Epoxied the wings together then glassed it I used 2oz on the wood cut 1.5in wide then 2 sheets of 3/4oz 2in wide on top of that. Balsa rite on that then iron the covering back down. If the covering does not last I’ll go back and put two layers of 2oz 5 in wide against the wood, and two layers ¾ oz 6in wide. The 3/4oz provides a smoother surface for reattaching the covering.
I removed the covers for the aileron servo’s. cut the male connector off it. Strung the red, black, and yellow wire through the wing past the center section and over to the other servo. Tin all the leads and soldier them up, so the servo’s are now connected together by the RBY wire. At the center section I strip back the insulation without cutting the wire, tin it then attach a male lead.
Now I’m getting the air components together, checking them for holding air before I install them.
Joe
ID:	624224   Click image for larger version
ID:	624225   Click image for larger version
ID:	624226   Click image for larger version
ID:	624227   Click image for larger version
ID:	624228   Click image for larger version
ID:	624229   Click image for larger version
ID:	624230   Click image for larger version
