RE: HL 360 Turret Ring
Rathead123: Power to the camera will be on as soon as you turn the tank on, before it's fired up. Am keeping the smoker. The red wire goes to the negative terminal on the gun motor right? That's because the motor spins backwards.
Amuro: The foil is on, the check out the bottom two photos.
dsketcher: The ring is wide to allow the airsoft unit to function. Remember, this mod is designed so everyone can do it.
