ORIGINAL: rob_crash24
thanks will a 28 push a 3ft boat its a under water drive as wel
Push, sure. How fast is the question. A .28 aero engine typically has less power than a sport .21 marine engine. For example, the OS .28 FSR engines had .8 hp. The OS .21 RG-M is listed at 1.7 hp. They also are not designed to run at the RPMs that most marine engines can handle.
