7CAP Twin Engine Setup
So, I'm sure I already know the answer to this but need proof that I made a mistake not buying the 9CAPS over the 7CAP.
Here goes...I just finished my twinstar and set up a mix for the throttle. One side master and the other side is a slave.
Just discovered the trim does not work nor does the throttle cut.
I am sure I know the answer because my UCD had an issue with the twin elevator servos.
So, my question..is there a way to make the twin setup work as far as the trim and throttle cut.
I think it is terrible Futaba didnt include this in their programming...which we all know they could do so. They did this so
we buy the 9CAPS.
So, now I have a 7CAP that is useless because I want to be able to set my end points on each engine servo seperatly,
and would like to remove the Y-Servo reverser from my UCD.
Now I will be seeking a 9CAPS Tx only, and if I didnt already have several futaba Rx's I would switch to JR.
