RCU Forums - View Single Post - Nitro engine with ducted fan in a car.
Old 02-19-2007 | 07:59 AM
janmaxx's Avatar
janmaxx
Default RE: Nitro engine with ducted fan in a car.
wow thanx for the info Barry!
2800w ! , thats interesting that should be a blast.
can you give me some more info on this system ? this is what im looking for if its not too expensive
what could the total cost be with ducted fan , motor and esc ?
and what type of aircraft uses this setup ?
i actually need to know how much circa the plane or jets weight who uses this setup , then i can find out if this motor is alright for the project.
is this the motor ? : http://cgi.ebay.com/Hacker-A50-10S-n...QQcmdZViewItem
also , im not going to start making the chassis before i have found the motor and fan i`ll use , so i only have ideas how i can make it now , but i liked the way the chassis on the batmobile was , but it`s not light ? do you guys have other ideas of light weight tubing i can use for soldering ?
im so glad you guys help me!
without you , this project would have been far behind
thank you!
