RE: My new CUSTOM SUPER INTAKE!!!
ill give you a tip for filters making it running lean: THEY MADE THE TUNING NEEDLES FOR A REASON. USE IT.
If too much air is comming in? set the idle or richen the mixture geez. The needles are also there to compensate. You could have broke a conrod for many reasons
And as for the filtering capabilities:
[link]http://www.knfilters.com/faq.htm#10[/link]
Thats a 97-99% overall efficiency rating using dust from 176 microns to <5.5 . Keep in mind no filter is 100%. I know the normal foam filters are cheap and efficient but dont say these filters are no good.
Enough said. Back to work for me.
