Because of the way the blade grips are made, a set of OEM blades will not move 180 degrees when mounted. You can move them one way, 90 degrees but when you move them the other way the root of the blade hits the hex head 3x6mm screw that secrues the blade grip to the feathering shaft.
So, it is not just you.
Carl
