RE: 35cc gass on diesel. is it possible ?
You could, if the compression ratio was high enough. The only way to increase the compression ratio to that required is to remove the top of the cylinder jug and make a new combustion chamber of the proper size. At this point you can use a conventional contrapiston. I've also talked with someone who used this method.
