80'' WM PW EXTRA Problems , Problems
Hello Everyone, Flew my 80 PW world Models Extra 300 Today. I wanted to tell you about a few problems I incountered.
I glued the tail section on after two hours of fighting with the blind nuts, After assslebly I still had movement in the tail section, I glued that together , Problem fix!
My Canopany had a 1/4 inch gap at the right rear section, I had to remove the covering and build that up.
the dowel pin fell out of the wing just before my first flight. this would have cause a major problem, like a total lost. I reglued that and checked the other just to make sure.
Re glue every joint you can get to.
I am flying Gas 44 Bme 8411's and PCM with simple smoke.
The Flight was Sweet, No Problems and the smoke was just cool. Good luck with yours
