RCU Forums - View Single Post - MK Skymaster 20 build
Old 02-22-2007 | 02:34 AM
vintageflyer
Default RE: MK Skymaster 20 build
Roguedog
Thanks for the praises.
your copy for the plans sould be pretty reasonable. Theres only the one sheet, and the sheet is only one sided! I also have been copying the parts as I've been going along, so reproducing the parts would be as easy as possible. Here's a pic of the fuse parts.
The graphite I used came in 1/2" wide strips and I cut them as needed. I don't remember the thickness or gauge it is. It was the thinnest my LHS had, and it's supplied by Aerospace Composites. Mind you, I only did this because I didn't have a regular carbon fiber pushrod around. If I did, or if I could buy one, I surely would have gone in that direction.
DM
