RCU Forums - View Single Post - What was your first engine?
Old 02-22-2007 | 03:06 AM
  #79
DarZeelon's Avatar
DarZeelon
Default RE: What was your first engine?
Since I don't consider the Cox and Testors rear-induction .049s real engines (but rather metal mosquitoes), my first one was an HB .40 PDP...
I learned a lot on it.
It was my only engine to ever shaft-run (wood prop not tightened firmly enough). The only one to ever break the crankshaft (hydraulic-lock and a starter...).
I also made the mistake of soldering an extension for the needle, with the O-ring inside it (old Perry carburettor - the high-speed needle never could hold its settings). I also made it run too lean and need a new ring...
But it was a screamer!
Friends with Webra Speed, Enya and OS FSR engines of the same displacement were amazed [X(] at its abilities.
