RCU Forums - View Single Post - Need Help please
Old 02-22-2007 | 12:07 PM
Gary.Mc.D.
Default RE: Need Help please
OK.
First off you need to insure your radio gear is switched on and working ie wheels move and the throttle linkage moves...
Keep the air filter on. It may instruct you to take it off to see if the throttle linkage is set up properly and also to insure there is a small opening in the carb...
Priming the engine...Put your hand over the exhaust outlet and pull the pull starter until you see fuel going through the fuel lines and into the carb...
The engine head (fins) inside there is a glowplug. Put the glowplug in and give the car short quick pulls (the glow start ignites the glowplug which in turn fires up the engine)
My forum has alot of help as well (even sign up) so check it out www.setbb.com/garymcdevitt
Best of luck
Gary
