RCU Forums - View Single Post - CX2 Flybar Mod?
Old 02-22-2007 | 09:42 PM
ndoren's Avatar
ndoren
Default RE: CX2 Flybar Mod?
ORIGINAL: Wnuk
I already have the linkages moved out to the 4 th hole on the servo arms and am real comfortable flying it that way.
Jim
Jim, beware of the 4th hole. If you go all the way diagonal on your right stick, the swashplate will bind on the lower hub if you go diagonal right and up, and it'll bind on the shaft collar of you go diagonal down and left. I don't think the swashplate was designed for that much travel. In fact, on the 3rd hole, I start to bind at the extreme limits of the right stick. Make sure you don't separate your swashplate as a result. Bad things happen then. Neall
