RCU Forums - View Single Post - 3w Ignition problem
Old 02-22-2007 | 10:39 PM
Tired Old Man
Default RE: 3w Ignition problem
Good call. My vote went to the Hall sensor. Using the DA would have required some extensive re-timing. It's been done a lot, but the CH replacement works out a lot better and is more reliable than either the 3W or DA. If the next one doesn't work out, go with the CH retrofit the next time.
