RCU Forums - View Single Post - Cooling space
Old 02-23-2007 | 12:35 PM
jaka
Default RE: Cooling space
Hi!
On modern pylonracing airplanes (.40 size) an opening of about 6-8mm and 20mm in height is all it takes. Then we talk high performance engines like IR and Nelson. Quadrouple the outlet area and everything would work out nicely . It's very important that the area surounding the engine cylinder and head is really tight, 1/4 inch is nearly too much distance, better to keep it as tight as possible
