RCU Forums - View Single Post - first crash, need help
Old 02-25-2007 | 01:13 AM
PutU2Sleep's Avatar
PutU2Sleep
Default first crash, need help
Okay, had my first crash the other day. Not a major one, had minimal damage. Only needed to replace the blades, spindle and an aileron and elevator link. After giving a look over and replacing the needed parts I have found that I hear a clicking sound coming from the clutch.....I think. Also I have noticed that no matter which way I spin the main rotor the tail rotor spins where as before it did not. The main shaft was still perfectly straight post crash, there are no missing gear teeth. I spun the rotor head and listened to the engine thinking it may be a broken crank but it is definately coming from the clutch area. The heli will also start with no problem and spool up no different then it did before. I'm thinking there must some type of damage to the clutch?
Any suggestions???
Thanks ahead of time.
