RE: Tailwheel conversion
Check these out instead [link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LXLGN7&FVPROFIL=++&s earch=Go]CLICK ME![/link]
Not only are they extremely cheap, but they are very easy to retrofit onto an existing plane.
There is little force exterted on the rudder, and the wire acts as a spring to prevent damage.
You can also adjust the tracking by bending the trailing wire when you are at the field.
