RCU Forums - View Single Post - mvvs 58 carburetor problem
Old 02-25-2007 | 05:12 AM
pe reivers
Default RE: mvvs 58 carburetor problem
There may be an issue with damaged reeds. Check the reed block, and replace the reeds if needed. (or have it done)
The reed intake engines normally have no blow-back at all.
It is normal for the reeds to be about 0.02" off the surface. Just check for broken or frayed reeds.
