mvvs 58 carburetor problem
My Feedback: (-1)
I have a mvvs 58 that runs stromg. At idle I see lots of gas spitting out of the carb is this normal?? I don't think so it just started doing it. What should I do?
Thank you
mark
Thank you
mark
There may be an issue with damaged reeds. Check the reed block, and replace the reeds if needed. (or have it done)
The reed intake engines normally have no blow-back at all.
It is normal for the reeds to be about 0.02" off the surface. Just check for broken or frayed reeds.
My Feedback: (-1)
I checked the reeds and one reed has a larger openning then the other. I'm guessing this is a problem. Should I replace or is there a fix for this? Will the Evolution parts "reeds" fit?
Mark
Mark
Evolution and MVVS are the same, but if it ain't broke, don't fix it.
