Originally posted by jeffmd2
Your engine should have a barrel stop screw also, this is to prevent the barrel from closing off all air flow. You will have to adjust this if you want the barrel to cut off all the air flow.
Don't forget to adjust the barrel stop screw (also known as the idle stop screw) so that you can close the barrel all the way.
