Savage break in?
Panic, we idled the first two tanks through. This takes a while. Be patient. Use break in fuel if you can get some. It is blended for break in. The key when breaking in, is the heat. On your third and fourth tank, make sure that you only blip the throttle and leave yolur body off. Take your time. There will be plenty of time to run Wide Open.
Later......
