RCU Forums - View Single Post - E-Flight Tribute
Old 02-28-2007 | 02:49 AM
  #49
flyboulder
Default RE: E-Flight Tribute
Added the CF l/e and replaced the rear elev hinge w/ CF and extended it out to within 3/4 of each edge. The forward main spar on the wing was also loose on one side so I peeled the tape back and CA'ed the entire length of the rod. I followed the suggestions (thanks!) and taped the leading edge as well.
I'll add the 3mm Fuze stabiler pieces from the wing to the tail tomorrow night but this has really stiffened the whole bird up quite a bit.
Not sure it'll need anything else except for a bigger motor to haul around the extra grams!
Chuck
