RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 02-28-2007 | 11:39 AM
  #1272
Stick Jammer
Default RE: Nitro models pusher Bobcat?
I used standard servos in the rear myself, and CG was good with an OS 46 - no extra weight needed.
Hmmm.... That's seems odd. I have an OS .55AX in mine which only weighs about 1 oz. more than the .46AX. Considering the engine is only about 6" behind the CG, 1 oz. isn't much. Mine balanced perfect at 10.5" from the wing leading edge at the fuse with no added weight. I have the Rx and battery right behind the nose gear block. If I had an additional 1/4 pound of tail servos I would certainly need to add nose weight.
