CH ignition & RFI problems
Guy's
i need help,i have a Taurus 52 with a CH ignition both new,i can't get over ten feet away from plane while it's running with out everything going nut's,that is with a Hitec 8 channel PPM rx,and when i switch to a Futaba PCM rx all is good over a 100 ft. away before it goes into failsafe.i went through everthing i could think of,there is no metal to metal any where,throttle servo is 10" away from engine and nyrod between servo and throttle arm with nylon clevis both ends.
the ground for ignition came with a eyelet that is ground to engine base bolt,does it half to be clamp to spark plug?the ignition has the rubber boot type over spark plug. there is 12" between rx, switch,battery and any ignition componets. this is the first time i had any RFI problems.
all idea's are welcome,THANKS!
