OS1.40RX with PD-06 pump
My guess is that you don't need to heat both plugs to start the engine... use the one that is mounted vertical, the other one will get hot very quickly...
If you want to heat both plugs you can also put them in series. All you need is 2.4 V instead of 1.2 V and one plug connected to the negative side of your power source and the other connected to the positive side...
