RCU Forums - View Single Post - OS1.40RX with PD-06 pump
Old 08-30-2003 | 05:11 PM
Rudeboy's Avatar
Rudeboy
Default OS1.40RX with PD-06 pump
Check the movement of the rod on the wrist pin... if it doesn't slide all the way to one side for one reason or another (gummed up oil for instance) you can have a hard time getting it apart.
If the rod is able to move all the way it should be no problem, because this is also the way the engine was assembled...
