RE: Removing Nemesis Diffs...
As correctly stated [link=http://www.loctite.com/int_henkel/loctite_us/index.cfm?&pageid=19&layout=3]Loctite 290 is a Super wick-in product[/link] that is primarily designed to lightly lock adjusting screws in place, after assembly.
As with all Loctite products, they can be used in multiple applications, you just need to pick the correct one for your [link=http://www.loctite.com/int_henkel/loctite_us/index.cfm?&pageid=20&layout=2]particular application[/link]. Sometimes the wrong product is used on a particular application, locking it completely. eg Our diff case screws, but as a lot of people have stated, heat in the correct place will fix this problem allowing disassembly.
Choose carefully,
.46NitroAddict [>:]
