RE: GP Cap 232
Did you connect the 256 rod to the choke arm permanently or used it to push or pull thru the hole then removed it for flight? After I removed the ball bearing I had a second thoughts but it worked....diding think of it wearing out, Y'up lesson learned. I'm going to tear through the Cap and see if I find anything loose or broke. Once again thanks for your help!
