RE: SIG KOBRA
My wing is almost finished , torque rods installed , just need to align them, ailerons are ready to be covered.
just need final sanding on the wing and then it ready to cover , until the rest of the plane is finished.
Started with the fuse , now busy with the firewall , might need to build a new one . Im going to use a OS 46 LA instead of the TT25 pro.
So the engine mounting might be wider, will see and test fit when I get the motor.
