RCU Forums - View Single Post - Problem with LT-40 Build
Old 03-02-2007 | 04:05 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Problem with LT-40 Build
Actually, that might just be the way to go. Do as you suggested and line the slots in the TE (trailing edge) with the ribs on the plan. If they all ribs on the plan line up with the slots in the TE then you should be ok. Just make sure the the ends of the TE stock are ok on both ends. You can cut off any excess that you may have. But if the stock is too short on either end then you can't do it like that.
Ken
