RCU Forums - View Single Post - crooked aileron on alpha 40 PLEASE HELP...
Old 03-02-2007 | 07:24 PM
bruce88123
Default RE: crooked aileron on alpha 40 PLEASE HELP...
This is ONE of the reasons for test fitting several times BEFORE applying glue. Once glue is applied it complicates things.
I assume you are calling the aileron torque rod the "shaft"??
Did you use epoxy on the torque rod? If you have a covering iron (household iron in a pinch) heat up the area near the torque rod and it MAY soften the epoxy enough to remove the aileron. Use a twisting motion instead of a pulling motion as soon as able.
Check the aileron and the wing trailing edge with a reliable straight edge to see which one is crooked. Perhaps both.
