RCU Forums - View Single Post - Tail Problem?
Thread: Tail Problem?
Old 02-15-2002 | 08:55 PM
glowplug
Default Tail Problem?
Last night I epoxied the vertical stab to the horizontal stab of my Thunder Tiger Lazy Tiger 51. The angle of the vertical stab to the horizontal stab is a perfect 90 degrees...BUT, If I put the square flat against the back of the horizontal stab, the vertical stab is not centered quite right on the horizontal stab. There is a tab on the leading edge of the horizontal stab where the vertical stab fits into, but I forgot to check to make sure the trailing edge of the vertical stab was centered on the horizontal stab. The vertical stab is a little over 1/16 of an inch off when measured from front to back. Do you think this will be a problem?
