RE: TB02R a good drift car?
C.A.R. , doesn't the stiffness in the suspension required differ if you're running hard rubber or ABS/Yok Rings? I read somewhere that with E-tape, you needed a stiff setup to break traction, but with ABS you needed as soft as possible, to get as much grip as possible.
