RC Drifting Discuss all aspects of rc drifting here!
TB02R a good drift car?
Old 03-02-2007 | 11:27 PM
mugenx's Avatar
Default TB02R a good drift car?
is the TB02R a good drift car, or does the parts like the TRF Damper Special make it harder for drifting?
Old 03-03-2007 | 11:33 PM
Default RE: TB02R a good drift car?
TB-02 R will do fine...
With the TRF-Shocks, just get some Medium soft 35-40 Weight Oil and Some Soft Springs and all will be good
They will actually help you slide..
Old 03-04-2007 | 12:36 AM
mugenx's Avatar
thx for the info, beacuse i am planning to upgrade my TB02 with TB02R parts.
Old 03-04-2007 | 12:17 PM
Er, well that won't make too much difference. The TB02R parts are all hard to find replacements for. Unless you have a new TB02R kit then you'll struggle to find all the parts.
You need quite a stiff setup for drifting, and usually that lies in the spring. The damper oil makes little difference, because anyone with any sense would just use a different piston ring with less holes in! The medium weight oil you get with Tamiya shock sets is perfect for all applications. You only want soft springs at the front, a stiffer rear end induces slides.
Chris.
Old 03-04-2007 | 12:49 PM
C.A.R. , doesn't the stiffness in the suspension required differ if you're running hard rubber or ABS/Yok Rings? I read somewhere that with E-tape, you needed a stiff setup to break traction, but with ABS you needed as soft as possible, to get as much grip as possible.
Old 03-04-2007 | 02:03 PM
Rs43EVOman's Avatar
Yeah with ABs you need to run a really soft suspension. Alsmost all guys startoff with 20W all around, and soft springs (i use tamiya Red soft's), and then you can modify from there.
Old 03-04-2007 | 04:07 PM
Lol, teaches me to use 2 forums at the same time. Ignore this lol.
Old 03-04-2007 | 04:09 PM
mugenx's Avatar
how about stabilizers? becaue right now im using the yellow(medium) ones for both front and rear. Should i switch front to soft(red) and rear to hard(blue)?
Old 03-04-2007 | 09:00 PM
Well in drifting stabilizers = nice touch to the chassis. They make little if no difference unless you're going round corners looking for maximum grip on rubber tires.
As for supsnesion settings in relation to tire choice then yes; I can see why a different setup may be needed.
If you run with ABS you get little traction at all; great for a stock car or any car with any type of suspension setup - even really soft.
If you have a different tire - especially the Tamiya drift tires - you'll wnat a stiffer setup; because it is harder to break the traction.
You also have to consider weight distribution on the chassis. I found this with my TA03F, that because I wanted a soft setup (maximum control) the engine and the whole front of the car dragged along the floor. And because I had to make that stiffer to support the weight of the motor, I had to stiffen the rear to counter-balance.
Basically; you always want to have a stiffer setup on the back than on the front, because this helps turn-in.
Chris.
Old 09-21-2009 | 09:25 AM
SIRCC's Avatar
looking for a 52 spur gear and tb-02r parts anybody got some
