RCU Forums - View Single Post - plastic fuse for SSC simitar
Old 03-04-2007 | 06:31 PM
OzMo's Avatar
OzMo
Default plastic fuse for SSC simitar
here is the first fuse for an SSC plane i'm trying out. very cheap and solid yet should have enough give to take a few hits.
parts are: $ store bat, and two golf club protectors, zip-ties and music wire. tail not shown will be 4 mil coro. it will have a motor mount on top of the bat that fastens on with rubber bands, but could be fixed solid if ya wanna. 7.30 ounces at this stage. cost so far $4.00 built in an hour or so. once one is good to go 1 hour to build would be resonable. battery and rx will be in the nose, throttle servo on the motor mount, elevons servos in the wing. the coro shown is just for spacing. the pieces from the handle act as reinforcers where the music wire goes through. tail coro will zip-tie in between the tubes. there will not be an elevator, ruder could be an option but not planned on at this time.
ID:	634979   Click image for larger version
ID:	634980   Click image for larger version
ID:	634981   Click image for larger version
ID:	634982   Click image for larger version
ID:	634983   Click image for larger version
ID:	634984   Click image for larger version
