RCU Forums - View Single Post - GT2 engine wont start
Old 03-04-2007 | 10:18 PM
rclynx's Avatar
rclynx
Default RE: GT2 engine wont start
FalloutMan you using a pull start? if you are go box or roto then you can prime by holding your finger over the exhaust pipe to prime it and get the right ammount of fuel in it most of the time. Also how long did you wait to try and start it again after the clean up? Just questions m8 to see if you went over it in your head cause God knows I screw up a lot I can't stress enough about no fuel being around that engine when you put it to bed for a few days, like running it till it dies with the fuel line disconnected, turning the truck upside down and draining the tank, blow out the lines, just what ever you can do to get that fuel away from the motor. I could go over at least 10 things that could be giving you trouble but don't give up cause you got to have the RC fix LOL. We are on the same coast and I'm on almost every evening so if you PM me I'll try and help. [8D] good luck [:-]
