RE: GT2 engine wont start
I am not for sure what your problem with the engine is, but here is what i do. First i take fuel line off from carb, believe it or not you might be way to rich, then try to start it without fuel line. If it starts after a bunch of pulls, than your gauranteed its to rich. #2 try loosening the glo plug a couple turns and try to start it, if its running to rich this will allow more air into chamber and let the engine run. I dont think you are to lean because you have already stated that the engine was filled with fuel once. Last but not least, i do not use aro because i have had problems getting vehicles started with it to, probably an error of my own. I use wd40, a squirt down the carb and a squirt down the glo plug hole, then 2-3 turnovers of the motor, and your good to go. I hope this helps a little.
