RCU Forums - View Single Post - 63S valve adjustment how-to
Old 03-05-2007 | 11:11 AM
Troy Newman
Default RE: 63S valve adjustment how-to
Usually you will loose top end performance when the valve tappets get loose. Usually they have to get really big gaps before the engine will be affected on idle and transition.
When the engines are new I run about 2-3 gallons of fuel and check them. Adjust if needed. After about 5-10 gallons I only check them about every 10-15 gallons.
good flying to you
Troy Newman
Team YS Performance
