help needed as usual
Check the servo arm and linkage and make sure it is opening up the carb. Check the carb and make sure nothing is blocking air flow. Check the entire engine and carb for leaks or cracks. It really sounds like a radio/servo type of a problem but check the engine to be sure....also check the gas tank and lines to make sure there are no holes that could leak pressure.
