help needed as usual
Old 02-12-2003 | 12:59 PM
Default help needed as usual
questions:
how do i know if my glow plug is fuked?
who retails Kyosho pureten parts (international delivery)?
and where the hell can i get after run oil from?
and last but not least !
where can i get my fuel from who will deliver it ..
seen as all the above questions i dont have a hobby sotre by me at all .. witch really blow's
the first question is my main 1 i need answering!
thx
Old 02-12-2003 | 01:53 PM
take the plug out of the engine, connect your glow ignighter, if all the oils don't light up evenly then your glow plug is weak or dead.
Old 02-12-2003 | 03:22 PM
glow plug seems to light fine and gives me a lovely roar! but car still cut's off .... been runing fine untill now :/ and ive changed nothin
Old 02-12-2003 | 05:58 PM
check the fuel lines and make sure there is no pinholes or cracks.
Old 02-12-2003 | 06:41 PM
bigbadbowtie's Avatar
As far as after run oil..... pretty much any type of automatic transmission fluid will work. If you can find marvel Mystery oil it will work also.
S&W hobby will ship there fuel. Its a very good fuel and they will mix it anyway you want it. http://www.s-whobby.com
I think tower hobby has kyosho stuff and they will ship anywhere.
Old 02-12-2003 | 07:28 PM
acceleration is ****in **** i open full throttle and .............. nuffin! it goes very slowly
Old 02-12-2003 | 11:24 PM
Default about helping .
#1 you need totest the plugand see if it good by taking i out and puting it in a plug glowstarter.and a the oil tower has the run ol you ned tere inmost of thetime not tax just shipping.and gas go to towerhobbies andget the fuel yo need 10 % or up.ten get it gal.were you can sve cash.it looks like a lot but its better to get it gal.you can get in gut.if you need to.if you ned anything more just ask ok..tylern later man
Old 02-13-2003 | 01:34 AM
think i understood most of that !
towerhobbies is a ***** to buy from.. prefer UK site's but cant find any for Kyosho
Old 02-13-2003 | 03:03 AM
Check the servo arm and linkage and make sure it is opening up the carb. Check the carb and make sure nothing is blocking air flow. Check the entire engine and carb for leaks or cracks. It really sounds like a radio/servo type of a problem but check the engine to be sure....also check the gas tank and lines to make sure there are no holes that could leak pressure.
Old 02-13-2003 | 03:09 AM
Does smoke come off of the glow plug? Mine lit up fairly well but smoke was coming off it and I was told thats not a good thing so I just order some new ones along with the other parts to get my car running lol.
Old 02-13-2003 | 09:58 AM
yes smoke did come off but that was fuel still on the plug! how can i check the engine for leakage? soz im no good with engine's :/
oh yeah another thing
i pulled the pull starter cord without my finger over the exhaust hole and fuel stil shot up the line? eh whyyyyyy could the port holes be blocked?
Old 02-13-2003 | 11:34 AM
yeah something must be blocking fuel, take your engine and carb apart and clean it out really well....you'll find the problem.
Old 02-13-2003 | 12:04 PM
lol i dont wanna take it apart though i have no experiance with engine's! the car parts easy but engine is a big no no! ill have to take the heat sink and manifold off and take a peak!
